Discuss Your First Job Tomorrow Morning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Enjoy
Better to send in Supperplumb ? probably only needs a bit of ptfe
Reading another thread .....
its a job for jet sweats!!! Or a bit of blue tack!
Got a call from a large hotel 25 miles away at 2am this morning. Once I had woken up the manager said you have to come out, it is very very urgent. I imagined a scenario like this and realised staying in bed was a much better option. Out came the, I am sorry but I have had a few drinks tonight so would not be able to drive out to you.
Thought it was the result of AP,s dodgy belly after one of his wife's legendary experimental meals.
Reply to Your First Job Tomorrow Morning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I have just joined, after being pushed into some DIY plumbing. Here is my first plumbing DIY effort. I had a cistern lever that didn't flush properly, and had become corroded and unsightly. I figured I'd get a plumber in to do it (after a couple of years apologising to guests for...
Hi, I am going to a job tomorrow where the customar says they have a 1 inch square valve head (what i would call a fire hydrant valve, maybe theres another name) in a manhole that turns the wrong way ie. Anticlockwise is off and clockwise is on. I'm in the Midlands and customer says some...
What's in YOUR toolbag? Please reply let us know and I'll compile a big list in the first post.
Hello all I have had an extension built which will have 3 radiators to the big main room, a utility sink and a shower room (ground works, waste, and pipes etc are in) The builder is not installing the sanitary ware as I will have to save up in order to fit the shower room in a few years time...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is switched on before it stops. There is a sink nearby, sometimes if we switch that on slowly before turning on the shower then the shower doesn't make a...
