Discuss Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Do these restrict flow at all? Someone has fitted 2 x 22mm strainers before a 3 bar shower pump and just wondered if they could be restricting flow (under normal use, not blocked with debris).
If there are now 2 different filters in a line then surely there will a slight loss.
Sorry, bad explanation, so there's one on each cold and hot supply..
No (if anything won't be much )
Changed hose to a large bore hose and new showerhead and custard was happy ;) happy days.. Cheers lads
Reply to Y Strainer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening, Wondering if i could get a little guidance, I have a 3/8 plastic line running from a softener to a coffee machine (because...
British Gas servicing the above boiler ramped up the boiler to maximum in the installer menu to do flue gas analysis. They also measured the...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
