Discuss Worcester Greenstar Expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
markadams
Serviced a boiler today that was over pressurising when heating up, so thought it would be a simple case of drain down and re-pressurise the vessel. tried that and found that the vessel would not take any pressure as if the valve was blocked, I removed the schrader valve but no change.
Any one else come across this? I removed the flexi hose which had debris in but not blocked.
Rubber stuck to the wall of the vessel due to over expanding needs a new one you might be lucky and free it off with about 4-6 bar of pressure but normally overstretched etc
Going to quote for both a replacement and an external, dont really fancy installing a replacement as its 3 floors up in a tiny cupboard with a horizontal flue.
much space above the boiler?
Reply to Worcester Greenstar Expansion vessel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
