Discuss Worcester Bosch sight glass issue? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
hi guys. I’ve heard about an issue with sight glasses on some of the Worcester’s but I’m unsure what the issue is. Any of you guys know anything about it please? What’s the procedure if you see one with a sight glass? Cheers guys
It’s usually the ones with the rectangle heat exchanger. Usually located where the ignition electrode is connected.
They have a red seal that goes hard overtime and needs replacing. Worcester have redesign it without the sight glass and a better seal.
Cdi
On the Electrodes there a sight glass normally cracks and burns through
It’s a recommended change as they crack
In theory yes as you need to set the gap
But most don’t
Why doesn’t the gasket sit down on the electrode?
Wrong way / side
Put it on from where your fingers are
Reply to Worcester Bosch sight glass issue? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
