Discuss Wood burning in conjunction with providing heating & hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumba66
Evening, I have been asked by the builder that I work for to look into providing a wood burner that can provide some of the heat requirements in conjunction with a boiler, to be honest I haven't fitted anything like that since years ago when we were installing parkways, , some questions,
are they efficient
how do you control the heat coming from them
what sort of controls are recommended
thanks in advance guys
Are you HETAS? If not then leave alone. Or bring in a HETAS guy in with you and pick up the info that way.
Someone suggested to me that I fit a thermal store (or at least have one fitted anyway). I've a Rayburn more or less ready to go into the kitchen and that's my plan. Thermal store will accept multiple heat sources. I'm hoping to get some advice and possibly even find a suitably qualified person to carry out some of the work. Ideally I can do the low techy and time consuming stuff. I'm not qualified though so don't think I'm allowed to realistically complete the job.
[QUOTEare they efficient
what sort of controls are recommended ][/QUOTE]
I'm no expert on any terms but my thoughts are, efficient only if you can get the wood for free or dirt cheap, can't control the heat much so need a vented system that's suitable for solid fuel - 28mm feed and return pipes etc. Thermal store I think should have the controls i.e. heating pump and stats.
It's a Rayburn Royal but I'm planning on fitting an enhanced boiler. Got top off already and the existing boiler out.
Haven't 100% decided yet. At this stage I could just fit fire bricks and do without the hot water, just heat the kitchen with the actual cooker.
Reply to Wood burning in conjunction with providing heating & hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Is it possible to install a wood burning stove with an air to water heat pump? I was speaking to a few plumbers who have said this is not possible as the air to water system is a pressurized system and the stove needs to be in a vented system.
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
I'm looking for a heating engineers/old school plumber to put in a Combi boiler (possibly Intergas) replacing very old open vent system in parallel with a wood burning stove with a back boiler (ESSE Bakeheart) as back up and alternative. I know this relies on two radiator systems. Combi for...
1K
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame to call for heat, and the receiver seems to be working ok with green light, but heating is just not firing. I really am not sure what the problem is...
