Discuss Wocester bosch highflow 400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DTBPlumbing
If the pump is hot and the boiler is not on what is that telling you ??
I'm not sure what's wrong with it. It's either over heat stat, blocked heat exchanger, problem with pcb or knackered div valve. The pump is running but boiler won't fire up. Think it's an electrical fault.
If everything else is cold and the pump is very hot then you have a faulty pump, have you reset the over heat stat ? have you any movement on DV valve
Ive had to pass the job on now as they needed it sorted quick. just bought Mr Combi dvd and multimeter, this will help in the future.
Sending your gsr details to REDSAW or Gas man would be pretty beneficial too.
Reply to Wocester bosch highflow 400 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
