Discuss wiring in the Central Heating Forum area at PlumbersForums.net
helpsy
Replacing an Ideal Mexico on a Y plan, fitting a Vaillant pure 425 with VRT 350f. normally have someone else do the wiring but can't attend. Does anyone have any experience having wired up something similar and have diagram please?
Would make sure it’s compatible as with heat onlys I don’t think it might be never heard of being able to use a plug in wireless room stat with standard controls / wiring centre you might have to switch to a vaillant brain and use there bus system
Reply to wiring in the Central Heating Forum area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi I seek some advice on replacing an existing regular boiler. I currently have an old Potterton 10-16 Netaheat electronic, which is around 35 years old and still working OK. It is fitted to a std 'Y' plan system with boiler in utility room and separate hot water tank, pump, valve etc in...
I have a ideal logic 30 boiler ,the thermostat receiver looks to have died ( no lights on wired receiver ) I believe this need# replacing but in the mean time does anyone know if I can override the thermostat if heating is required please? the handheld thermostat is working it’s the boiler...
Customer complains of Intermittent heating on Y plan with Stat satisfied. New boiler fitted last year (no permanent live required or fitted previously) on an existing Y plan system. Existing timer was a Randall 103 (no hot water off position as its a timer not a programmer). The customer wanted...
2K
Does anyone know please what kind of fitting this is? I have hot cold wallmounted faucets for a bathroom basin. The original taps (pictured were not gripping and slipping around the pipe)I was told by a plumber that he couldn't find any similar taps with a fitting like this (some sort of...
