Discuss Why is my carpet wet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tweebs1
Hello all,
My partner and I just moved into a conversion flat on the top (2nd) floor of a house built around 1900. This morning around the time when the heating came on we heard a dripping sound come from the ceiling above the bedroom. We had a poke about in the loft, but there didn't seem to be any water up there, and no signs of damp on the ceiling itself. I also noticed a wet patch on the carpet in the bedroom - but again, no visible water dripping from the ceiling onto the carpet and not even any signs of damp on the ceiling above the wet patch.
In a possibly unrelated matter (but thought I'd mention just in case) the toilet keeps trickling water for a really long time (hours) after being flushed. Now, I imagine the drip sound is just the creaking of the pipes and/or timbers, the wet patch is just condensation and the toilet issue is just a damaged flapper, but I'm still concerned it could be something more serious. Any other suggestions would be welcome!
Cheers,
Pat
either inspect more under, around and above the wet patch then reply here if you find a leak or get a plumber in only way we can help without being there really as for your toilet most likely the ball valve has failed as is going through the over flow but get a plumber in to have a look, could take them no time at all to fix these problems, and if you have a combi and its a heating pipe leaking you wont have heat for much longer when the pressure drops
Hello Pat and welcome to the forum.
It's a bit of a difficult question without being able to see.
is this a one off?
could it be a spilled drink, a cat that doesn't want to venture out into the snow??
is the wet patch close to a radiator, could that be the problem?
best to keep an eye on it until you know what the cause is, then a solution is possible.
is this a one off?
been there lol saw water on a kitchen floor and felt to see where it had come from to see a small yorkie in the corner looking at me - yes it had and i had touched and knelt in it
Thanks to all for the replies! I'll have a another good look around the damp area and ceiling and will keep an eye on it today and tomorrow. Partner is off on Wednesday so can get a plumber in then if not resolved...
remember water travels quiten well if you can get into loft lift the insulation and check around the patch
Hi, Tweebs1. Try removing cistern lid and check how high the water level is. Usually there is a mark inside to show the normal level. If it is higher than it should be it can spill discreetly down the back of the cistern or out of a spindle hole etc
is there a extractor fan above damp patch on carpet. i have seen before water drip from these as the steam from showers etc is drawn in then where the loft space is so could it turns back to water in the pipework and prips out.
Reply to Why is my carpet wet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There's a leak in the ceiling of my Dad's living room which is on the ground floor and has a bedroom directly above it...
I have a growing damp patch on my ceiling, I initially assumed it must be from the empty flat above (and therefore cannot gain access), and have...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hello, Can anybody please advise. For months now our old Ideal Mini HE C24 (combi boiler) has had pressure problems. It won't stay above 1 bar...
2K
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
