Discuss Where can I find a 300mm wide 400mm high or nearest in chrome? in the Central Heating Forum area at PlumbersForums.net
Thats great, I will check with my plumber and go for it yes it is for central heating but they also do the pre-filled electric as well.
You can have it plumbed in, and with an electric element in it as well (with the necessary chrome T-piece) - ie "dual fuel".
Handy where it's on the radiator circuit and you want the towel rail warm in the summer.
Just have to remember not to leave the element on in the winter!
Does anyone put towel rails on the primaries any more? Then they heat in summer when the water only is on (albeit probably only an hour)
My preferred arrangement is a dual fuel on CH primaries with TRV for hydronic control and a Timeguard four-hour countdown timer as a fused spur (in a safe zone). Fairly easy and intuitive to use and avoids accidentally leaving it on leccy for days at a time.
Reply to Where can I find a 300mm wide 400mm high or nearest in chrome? in the Central Heating Forum area at PlumbersForums.net
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
Hi, Recently had a new heating system and unvented hot-water cylinder installed (conversion from vented with tank). Everything is working fine...
O
im a DIYer remodeling my master bath. long story short, after tiling my toilet flange is too high. im aware of all of the options to repair, but...
Hi my daughters Ariston Cylinder has started to leak around the Emersion heater. She has never used the emersion heater so I was wondering if...
Hi all, I'm in the process of fitting my freestanding bath. The supplied waste chrome pipe that runs into the floor is an unusual diameter -...
