Discuss When does plumber first fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yep every site I've worked on the site agent has a copy, if not then wait for confirmation but as a start do NOT drill/notch the top or bottom part, sounds obvious but some think it's okay!!
Is it copper or plastic being used?
If it's copper you need to be before the floors and stud work go in find out the sizes of rooms then bring pipes up where needed, if it's plastic then after floor and stud work.
Why would you do copper before floors on a tji? You can't notch it so won't make an odds other then the bird cage being in your way as there's no floors in the plot
I would first fix once the upstair floors are down but no floor downstairs ( if solum ) . B4 any plasterboard and most important b4 the sparks lol
Thanks can the pre knocked out holes be knocked out anywhere on the span or is it 0.25 to 0.4 of the span like on normal joists. And for drilling is it 0.25 to 0.4 of the span
Reply to When does plumber first fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
