Discuss When does plumber first fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
On a building with modern engineered joist that you knock out. When do you first fix usually after the floor and all stud walls have gone up?
preferably before the plasterers arrive and cover things up or the chippies board the floors
Yeah then you drop your rad tails in the stud work, turn your domestics up in place for bathrooms. Then sparks do there bit then chippies add noggins for rads, dry liners in, mist coat, then free for all on second fix and finals
Thanks got one to start with no floor down upstairs or stud work yet. But work want me to start it explained there wasnt much can do yet.
I like to have the floors down, studwork in and boarded on one side.
yep,after the 1st floor is down and stud work is up. sometimes you'l have one side boarded.
PM me if you want the measurements we use for tail, rad heights etc.
The knock out holes on the engineering joist look a fair bit out of alignment has anyone had this before? Also can you knock the pre made holes out anywhere on the run?
Knock out only ever line up for sparks and thier flexible cables. Better off to drill the plot out
Reply to When does plumber first fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
