E
Ermintrude
Stan do u do quotes or does some one give you the work? Have you advertised?
Discuss When Customer Says You're Too Expensive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
wuss:sleep1:I will be too if I was driving a landy LP pmsl
Hi Bert large, I am guessing you are a firemen, ever plumber I have met in southwest is a part time firemen!! Day rate can vary up here, from £200 to £450, depending on quality of work, customer base etc. I believe southwest (Cornwall and Devon) is maximum of £200 per day but as you say easier workload, less pressure. The big difference is the hourly wage, southwest is £20-£25 per hour, so still earning around £200 per day, up here you can charge £50-£75 per hour so potentially £600 per day. And emergency callout, you could get away with £150 per hour for out of hours emergencies. Depends how busy you are and how much you need the work
Thats not London, I'm in bucks. I ain't bothered in telling people what I charge, why the secret?
Reply to When Customer Says You're Too Expensive in the Plumbing Jobs | The Job-board area at PlumbersForums.net
