Discuss whats it called and where do i get one in the Plumbing Jobs | The Job-board area at PlumbersForums.net
ambrosia
guy from transco had a cool tool that was a cross between a screwdriver and a socket which was specifically for taking the nuts off of meters test nipples
it was like a screwdriver in that it had a long shaft and a socket in that it went over the nut and held it till you screwed it back in to the meter
it had a handle which looked like these allen keys
DRAPER 35383 10PCE T HANDLE METRIC ALLEN KEY SET IN STAND 2MM TO 10MM | eBay
far better than struggling with a screwdriver or risk snapping those nuts with an adjustable spanner
I want one but can find where you can get them from, somebody point me in the right direction
thanks
I don't know what's it called but I'm sure your plumber should have one that's where I got mine from.
thanks
I have 2 made by CK grey handles 8mm fire, SIT gas valves test points etc and 10mm for meters, i asked for sockets drivers
The one and only tool I've ever bought from the pound shop was a socket set for this very purpose, the handle is narrow therefore you don't get much grip ( perfect so I don't snap the text point) I've taped the 10mm socket onto the bar to stop it falling off when I put it in the (screwdriver) side pocket of the tool bag
I chucked the other sockets in the bin haha as I only wanted it for test point I've had it for years and its still going strong
I just use a screwdriver, or failing that an adjustable spanner!!
Yes I could use a nut driver, but never felt the need to be honest.
Reply to whats it called and where do i get one in the Plumbing Jobs | The Job-board area at PlumbersForums.net
