Discuss What the difference betwween part 1 and part 2 Ball cocks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi rab250
Part 1 = piston type(outlet below main body,requiring non return valve to be used to prevent backflow)
Part 2 = diaphragm type (outlet above main body)
Correct me if I am wrong but I have ever heard of a non return valve on a float valve, the air gap is the back flow preventer and with the overflow the level of water should never be able to reach the valve.
Correct. There's no check valve in a part 2 float valve.
Reply to What the difference betwween part 1 and part 2 Ball cocks? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys in the know. I have paid for a heating and plumbing contract and had to pay my excess 3 times for the same thing still not fixed. The...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into...
Rogelio
R
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
Hi everyone, I'm a (somewhat, I hope...) competent DIYer and just want to get some advice if my suspicion on a problem we're having is correct...
