Discuss What is this mystery pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
E
Emma Walsh
I am renovating an old mining terrace in the Welsh valleys (uk) and I have come across a mystery, I have my mains water supply to my property and a stopcock near the front door that cuts off all water to the property. However I also have blue pipe coming from the floor in my kitchen, also with a stopcock, which i assumed was the cold water supply to the kitchen,but it is not.
We have just had the plumbing redone and the plumber assumed as I had that this was the cold water. The stopcock attached stops the water cooing in to this pipe not out?
So we have turned it to closed and it has had no effect on the water supply to the property.
Can anyone help solve this mystery??
Out to an outside tap or out buildings ?
Reply to What is this mystery pipe? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi All After having pooling water on my drive, I dug down around to find: Black pipe poly/plastic dug 450mm deep spraying water at mains...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hello I have a mystery, my bathroom has a sewage smell appears to get far worse 5pm-9pm. I have plugged my bathroom/sink with plugs and its 100%...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
