Discuss What is the best way to drain down the heating system if there is no drain valve ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I always do the above method with George.
You can get a self cutting drain cock but they only cut an 8mm hole so takes longer to drain. If you use one then replace with a proper one once drained and keep the other one for next time.[/QUOte
Dont chippies use self cuttig drain cocks in the form of 6" nails, they leave an 8mm hole
Reply to What is the best way to drain down the heating system if there is no drain valve ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
