Discuss What is the best Combi Boiler ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Benphilpott
I need to fit a Combi boiler, just wounderd what you guys would recommend? Any outstanding makes out there ? the house has 7 rads on the system & 1 medium sized bathroom.
Hmm!
As most combis seem to have a bad record for reliability get one you can get spares for easily.
Hmm!
if you buy cheap expect them to fail quickly, the more you spend, within reason the better you get, talk to who your using to install your boiler and use what they recomend after all they are more likely to be the one coming back to repair and service it and theyll know one or two makes better and hence give you a quicker install and better back up
remembering that you get everything in one package, so when the pump/ Div valve/clock goes, you blame the boiler..most of the time it is bad installation practices..:(
I stick 30 odd boilers in a year and very rarely have any problems.
Valliant or Bosch - Bit more expensive but worth it in long run
Reply to What is the best Combi Boiler ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
Evening Hopefully you're not sick of this type of question! I've had a few quotes for a boiler upgrade (going from a regular boiler (~15 yrs...
7K
Deleted member 131795
Hi All, We may need to replace our boiler - the OLDER version Worcester Bosch 35Cdi (see images attached) Our home is a 1920's Semi 5 Bedrooms...
7K
Old Account
O
Hi All, First post here, so please be kind! I am currently having a lot of trouble with air and related noise in my open vented heating system...
22K
  • Locked
We have recently bought a 3 bed terrace which currently has a 9yr old Vaillant ecotec plus 415 which heats the radiators and water storage tank in...
4K
