Discuss What cartridges ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Did anyone else win an IPad when you clicked on the zippy share link above?? Gonna put my bank details in now to claim my prize.......
£50 for new one!!
if these types and variety of valve that all do the samething were designed in germany they would have been facing a wall by now!!lol
The issue is that the temp. Site doesn't work anymore what do you think to do best off change whole valve or trying to get the cartridge ? Or you have got a solution to fix it ?
Replace with a whole new valve and fit a new rail, unless the valve was £200++
there not worth the hassle replacing the cartridges, even if you find the right one it'll end up being seized in and wont come out
Yeah, thanks buddy already cleared off with the customer. It's hard sometime with clients to deal with such problems they think you want more money ... But I explained him the issue and he is going to buy one.
Thanks anyway for all the plumbers they tried to help me.
Looks like one I've recently replaced. I've found that the brass cartridges seize up quite quickly (and in some older cases the inside of them have completely disintegrated!). I've found the plastic Vernet cartridges are incredibly reliable. I've never had a call back from a customer who needs me to go back because it's had a problem, and that is gold to me, and the customer. This is the one I rekon will be a good retrofit for your brass cartridge there (this is just based on the end of the cartridge, the splines, number of teeth on the temp handle. I'd need to see a photo of the cartridge outside the valve to properly identify it. But anyway, I rekon this'll do the trick:
- Vernet TMV2 Thermostatic Shower Cartridge Replacement CAWH08-05
Looking at those photos again, I just fitted one of those Vernet CAWH08-05 cartridges (in the link in the previous post) in a valve that looked identical to that one, so that fills me with even more confidence it would work.
Reply to What cartridges ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
I'm replacing the shower cartridge on my Bristan 1901 Thermostatic Exposed Dual Control Shower (Top Outlet). I have removed the cap and screw but...
AlexTTT
A
This is driving me bonkers! I have a Jaquar shower mixer unit - which has started to leak from the diverter cartridge. I think it's an early...
I've just replaced an Ultra SASF2 – M thermostatic shower cartridge together with the spring mechanism and the temperature sensor. My problem is...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
I've got a Glowworm Flexicom 24hx boiler and I'm trying to unplug the installer cartridge in order to wire up the ebus connection inside. From...
