Discuss What are you using to cut stainless 88.9mm pipe. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
We are using a the rigid 65s pipe cutter for the smaller stuff but we have a load of 88.9mm x 2mm stainless coming up and was looking for a decent pipe cutter. Any suggestions?
Rems cento
Bandsaw that’s only the other option other than like you have rotation cutters
We use these for most large pipe work (2 1/2" - 5") or a hand held 9" grinder if larger pipe
Flapper disc to clean burrs.
View attachment 76753We use these for most large pipe work (2 1/2" - 5") or a hand held 9" grinder if larger pipe
I wouldn't trust my guys to deburr properly and safely. It also leaves me a big problem with hot work permits. The cento looks like the way forward, its a bit more than I wanted to spend as we will be back to 54mm after this job but if it makes the job easier it will be worth it.
You can hire them by the day/week.
I have 100m of pipework to replace with the onsite engineers and it has to be done in production time so it will probably take a couple of months on and off. We are probably saving £40k doing it ourselves so in the grand scheme of things £1200 for a decent cutter isn't going to break the bank and at least it should avoid the badly deburred pipe damaging the orings. Thanks for the advice everyone.
Reply to What are you using to cut stainless 88.9mm pipe. in the Commercial and Industrial Plumbing Forum area at PlumbersForums.net
Sonya K
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
