Discuss water hammer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chin00k47
Firstly, I am useless at plumbing!!
I need one of those devices to stop water hammer. My question is that under my sink I have a spare 3/4 inch male cold water connector (the ones you plumb your washing machine hose onto).
Are there any devices out there that I can screw directly onto this connector to save getting a plumber in to fit it in the middle of my pipe somewhere??
nope,
by the sounds of things the 3/4 connector you have will if fitted with a pressure reducing valve would only stop the waterhammer to any outlet downstream ie the washer!
if you want to reduce the pressure you need to fit a valve closer to the stop tap than any branch pipework on which the problem occurs
Depends where the water hammer his happening. Mine happened when the watering system filled to the outside tap operated. A common problem with watering systems apparently despite a pressure reducing piece as part of the fitting. It occurred on nothing else. I made a diy device via a tee onto fitted to the pipe fitted to the tap. You can buy a water hammer arrester though. Does it happen throughout or is there a particular device that causes it.
My water pressure is not unusually high (about 3 bar). The other question is how high is your water pressure. If it is high or if the problem is throughout then, as kay-jay says above, a pressure reducer after the stop tap.
Reply to water hammer in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I've got water hammer issues with my cold feed and some with the hot feed. When the cold sink tap, cold bath tap and thermostatic shower in...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom...
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
