Discuss Water dribble when soldering in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I'm a complete notice and I working on my heatings motorised valves on my S plan system. I was modifying the system to add an arrester. Long story short, I made a bodge of the soldering due to persistent tiny water dribbling in the pipe being soldered which I overlooked despite the system being drained. How does one get around this? I heard of people using bread but that won't work here I won't be able to retrieve anything from the pipe afterwards.
Does it keep running / dribbling if yes use a compression fitting
Cool. I didnt think of that. I wonder if I left it dribble for a few hours, maybe it would run out of water so to speak
Could be or you could try using a wet vacuum to suck it out and quickly solder etc
Using bread is fine as it just dissolves in the water when filling so you dont need to remove. You don’t need t use a full loaf though just enough to soak it up to stop the drip. But failing that as already stated use compression
Or press fit.
Or get a small bore hose, insert in to pipe and blow/suck the dribble, then solder quick before it comes back.
Or open a drain off/compression near by to divert the drip.
Reply to Water dribble when soldering in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi, Short version: Do frost protection valves trigger when the water in the pipe gets to threshold, or when the air temp drops? Long version...
L
Hey everyone, I'll keep it short. Had our old system boiler replaced with a new Ideal system boiler set up. Then the problems began. First...
2K
Hello friends - I really struggle to understand my heating and hot water system I posted my question on Diynot but it ended up being five pages...
