Currently reading:
Waste water pump
Discuss Waste water pump in the USA Plumbers Advice area at PlumbersForums.net
Matt0029
Hi can anyone recommend a good waste water pump. For clean water so won't need a macerator bit. It's for a waste run that now has 6 meters pipe with a fall of 20mm. So well out of limits for the required fall. Has been tested yet but I don't think will work without a pump.
With hepVo traps you loss about 10/20 between inlet and outlet.
There's the mcalpine one that is straight so wouldn't loss any fall on the trap like the hepvo. But sure I read somewhere these aren't to be used on showers. So may not have the force in the water to open it? Thanks
It’s more todo with hair keeping the valve / flaps from closing
Reply to Waste water pump in the USA Plumbers Advice area at PlumbersForums.net
