Discuss Washing machine hose connector not screwing on fully in the USA area at PlumbersForums.net
Hi! Sorry we are first time buyers! So May be a stupid question! The water hose for our new washing machine doesn’t fit the water inlet? (Photos attached). It screws on but not all the way, and if I open the valve it sprays water everywhere. Do I need a connector or something? Any help/advice would be greatly appreciated!
They look like standard appliance valves, with an adapter screwed on (black bit).
If you add a pic showing the back of the adapter/opposite end of the valve to the 15mm compression, we should be able to confirm. Or just get a spanner/grips and remove the black adapter and the hose should connect correctly.
Hi Timmy,
does this help??
Remove the black adapter
it should undo off the silver valve
One piece
yes the valve is threaded to accept the machine hose
Reply to Washing machine hose connector not screwing on fully in the USA area at PlumbersForums.net
