Discuss Vokera Linea Max Heating Turning On in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What could the possible causes be of the heating turning on at random moments and for various amount of time on a Vokera Linea Max combi?
For instance, the digital programmer was set to 'override On' for the evening, then to 'override Off' at night, and the heating came back on all night whilst the programmer still showed it to be off in the morning (unsure what it may have showed during the night). In another scenario, the programmer was set to 'override Off' AND the dial was set to hot water only and yet the heating still came on.
Expect an appropriately trained engineer could find out. If your a shoemaker it's probably elves! Cold at night!
Reply to Vokera Linea Max Heating Turning On in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up a flashing 79 code. Try restarting the boiler straight away but I have to wait 10 minutes for it to cool down before it works. I reset the boiler...
1K
J
Morning all, My Vallient Ecotec Plus 831 is stored in the loft and is connected to Hive. It is coming on randomly at various times of the day, but particularly middle of the night, and staying on until I manually turn the boiler off. Hive schedule is switched off but still comes on. Had an...
J Hughes
J
Hi I'm dealing with Vaillant Ecotec 824 R1 in one flat. The boiler make a very loud noise when central heating is on - this is random and occurs mostly at night. I'm sharing video showing the problem: So far we changed: 1. Expansion vessel 2. Pump 3. Water pressure gauge - analogue sensor...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a lot of installs or a tremendous amount of gas work but obviously when I do undertake these things then I try my best to keep within the appropriate...
