Discuss Vertical radiator on single stud? in the Central Heating Forum area at PlumbersForums.net
Hi, I have an internal, decorated plasterboard wall with poor studding: from left to right, there is a 22mm wide (i.e., horizontally parallel to the wall) stud, then a 38mm stud (the two studs are spaced 60cm), then the jack stud of the door.
I need to hang a ~2500 BTUs radiator (I have gas central heating), and I'd prefer to avoid both hanging on plasterboard and adding battens/noggins to fix the brackets.
So I thought to fit a vertical radiator (total width 27cm) by fixing all the four brackets to the 38mm stud via steel plates/flat brackets similar to this one:
https://res.cloudinary.com/rsc/image/upload/b_rgb:FFFFFF,c_pad,dpr_1.0,f_auto,h_281,q_auto,w_500/c_pad,h_281,w_500/F3975008-01?pgw=1
Would that work and be doable?
Any suggestion welcome.
Yes it would work as long as you can get a good fixing to whatever metal you decide to use.
Saying that, I think you’re overthinking it. Just get some plasterboard fixings. I think 6mm toggle bolts on 12.5mm plasterboard are rated for 15kg. 4 fixings = 60kg. Can’t imagine your rad weighing more than that.
You're probably right, I tend to overthink things. That said, not using plasterboard fixing gives me some peace of mind, also because the plasterboard is only 9.5mm. Would probably still be ok, but...
Reply to Vertical radiator on single stud? in the Central Heating Forum area at PlumbersForums.net
