Doomageta
Hi there,
Looking to get more advice as a couple of plumbers I called I told e different things and i want o get it right.
I am adding a ensuite to a room and was planning to get it connected to the existing main drain running along the back of the house (where existing bathroom and cast-iron soil vent pipe nearby are installed) and then down the side. Looking to Tee off from the existing pipe to new ensuite (in red on the attached picture if it shows).
One plumber said i need to turn the pipe that comes from the gutter into a 4" vented stack pipe that all the waste from the ensuite will connect to a well as the rain water.
Another said that they could just tee into the drain without needing anything else done since it is so close to the main drain pipe that we will tee into.
What is right in this case?
