Discuss Valient Ecotec Plus 837 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
rowedout
Hello, I wonder if anyone can help. We have an excellent Valient ecotec plus 837 boiler controlled by a Honeywell wireless programmable thermostat controller.
The system at the moment seems very noisy, principle problem is when it is turned to manual and the target temperature is set at 23C the heating is on for approx 5 minutes then turns itself off for a couple of minutes then on again (repeating itself) - it does this without being anywhere near the target temperature.
Do we need to get it checked out or is there a simple problem to be solved here?
Many thanks for any advice.....
Adam
Check all of your trv's are set to number 5. Also feel the flow pipe. See if it gets warm
Sounds like you might have a circulation problem
If this is the first time you have run your heatin since the summer you may have stuck trv's
check the water pressure is ok for a start. when the boiler initially fires it is a bit noisier than normal but it settles down. I assume your hot water works absolutely fine? As above sounds like a flow issue. The heating flow and return isolation valves on the underside of the boiler are fully open i assume?
Reply to Valient Ecotec Plus 837 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
Hi We've got a Vaillant ecotec plus 428 that doesn't seem to want to supply any heat to the radiators despite the hot water working just fine...
3K
Our recently installed (last week) Vaillant Ecotech 832 Plus does its own thing and heats constantly regardless of the controller mode...
Hi, Am trying to understand my mother's Apollo boiler. It has an intermittent fault. In the last couple of years, it has had a new...
Hi there, thanks for your time to look at this record long post!! I work on the operational management side or a small building contracting firm...
