Discuss Valiant vrt 230 replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, I have to replace a Valliant vrt 230 stat/programmer. Can you advise a direct replacement/alternative for this discontinued item.
TIA
It’s for a rental property, so one which will provide similar functionality to the existing (and not need rewired!).
Cheers.
Reply to Valiant vrt 230 replacement in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
