Discuss vaillant, failed today! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
turbomax plus 834, fires up for a min or so then goes off then cycles again. pressures 1.5bar.
f22 on index fault.
there is no heat transfer on any pipes below or inside boiler from p-hex apart from h-ex f&r pipe! pump and fan running!!!!!!!
help
gone home:disappointed:
Pump or divertor Knackered or blockage. Sometimes faulty thermistors give F22.
it says dry fire!
there was a small weep above the therm on the high stat that was dripping on it but i sorted that and dried it!
my initial thought was the motor pin on the div-valve but thought it will be open to heat or hw though?
cant understand why its not pushing anywhere down pipes unless its blocked solid!
ta
What resistance are you getting on the primary(CH) Thermistor
Agree with this. Sounds like you've ruled out the thermistor if 15k ohms at room temp? Look at the pump and diverter.
Sounds like a blockage to me, check filter/strainer and pipework internally from primary heat ex as well as what above have said
Reply to vaillant, failed today! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Vaillant eco plus 837, year installed 2008. It works well. We have one large zone for the house with 13 rads running off it. We also...
I need some help from the internet before I waste any more time and money trying to fix air getting in to my central heating! Looking for advise...
2K
Bronze Body DHW Recirculation Pump. Excellent Price. Only £77.00 Ex VAT BUY HERE Bronze Body DHW Recirc Pump Model : Bronze pump BRZPUMP-C...
1K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
I do not know anymore.i bought a home.in spain.top floor(4rth floor) I get a horrid stink in my apartment every time thebperson Below me does...
Aquarius
A
