Deleted member 120897
Yep or Dan/Lou?One for Shaun John ????
Discuss Vaillant EcoTec Plus 938 temperamental in heating mode in the USA Plumbers Advice area at PlumbersForums.net
It's still a strange one though because if the diverter valve was working originally its hard to understand why not enough water flowed even if the bypass was fully closed, the diverter valve should have directed the primary water to the zone(s) valves which presumably opened at the same time and even one rad/towelrad should provide the minimum flow necessary.Pump was always at 100%. Will post some charts on temps later
I actuall registerd under a new name and Lou welcomed me on board so I replied explaining my problem.Yep or Dan/Lou?
Hi John,Why do I have to reset my password each time I log out since this morning?.
Thanks Dan, Yes, I'm using my saved password each time in resetting and clicking the remember me box and also the stay logged in box.Hi John,
We're toying around with a new advertising partner and that might have something to do with it.
Although it does appear as though your computer isn't remembering your logins, and you're simply resetting your password to login, rather than using the last password you chose?
(Don't ever write passwords in here, I'm sure you wouldn't have done already but I thought I'd let you know and say this)
If it happens again could you please try to clear the browser cookies, close the browser down, then reopen it, login, and check the box to remember you each time you visit (only providing you're using a computer only you have access to.
Well, I think I spoke too soon. It's doing the same thing again... Adding more turns on the internal bypass did not help - put it back to the original position now. Does this boiler not have a flow rate sensor for the heating circuit? I'm sure the flow rate is good, because I have 3 towel rails all fully open and they heat up very quickly when the boiler outputs 60C.It's still a strange one though because if the diverter valve was working originally its hard to understand why not enough water flowed even if the bypass was fully closed, the diverter valve should have directed the primary water to the zone(s) valves which presumably opened at the same time and even one rad/towelrad should provide the minimum flow necessary.
D.001 - 5 minCan you also check d.001, d.002 & d.018
Reply to Vaillant EcoTec Plus 938 temperamental in heating mode in the USA Plumbers Advice area at PlumbersForums.net
