Discuss Vaillant ecoMax 828/2E (VUW GB 286/2-C) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi
I wonder if can someone offer any solution... I have a Vaillant ecoMax 828/ 2E boiler which is leaking. To start the repair do I need to adjust the diverter valve to the middle position to purge the boiler? If so what function on the program do I need to go to adjust the diverter valve to the middle position?
The leak is not coming from the diverter valve, but from the end side of the pipe that is connecting the aqua valve to the secondary heat exchanger, (12 plates).
Yeah, quite a common place for it to fail. Unfortunately as the case forms part of the combustion circuit and you’re not in the gas engineers section, forums rules forbid us to give out gas related advice (I know it’s water but as I said, part of the combustion circuit).
Reply to Vaillant ecoMax 828/2E (VUW GB 286/2-C) in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
