Discuss Unvented install on a combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
Hi
I need to install an unvented cylinder along side a Worcester green star heatslave 12/18.
cust wants the boiler to supply hot water to the kit tap and the tank do a bathroom and cloak.
is it possible to wire the tank and zone valves back into the boiler to allow operation?
we will have a programmable room stat with the heating zoned and the hot water tank with a timer.
am I missing anything????
regards
Chris
Just convert it to a s plan. Timer fir hit water and prog stat for heating.
Tbh I think a combi with a pressurised cyl is the ideal solution. Water used during the day in the kitchen fed from combi and then decent flow to bathrooms fed from a cyl, timed for only a few hours a day.
Should be fine but if you get any problems wiring it up just shout will draw you somthing up
Reply to Unvented install on a combi in the Plumbing Jobs | The Job-board area at PlumbersForums.net
