Discuss Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have 170l on HW Priority and well, it's not enough (Cylinder was existing in house when we bought). 2 People at 20lpm showers. It reheats rapid (Maybe like 10 minutes), but personally if you've got the physical room i'd go with a minimum of 250l. Especially in a 4 bed house.
You don't need fancy controls. You can do it quite simply with a relay that costs £15.
Intetesting, im listening....
I often spec for 'Gledhill platinum stainless indirect' cylinders. I rate them and they have the floating baffle that eliminates need for expansion vessel and adds a decent amount of accumulation that may help with your 'pressure' issues
No go for the plate heat exchanger with your current sized boiler.
330i is a rebadged Glowmorm boiler so she's getting on a bit now probably over ten years or more but if well maintained and serviced I'd connect to a unvented cylinder or you may want to consider a boiler upgrade at the same time , but as Timmy has said not suitable for a plate heat install as it is .
Yeah, thats the one, it still works and gives us heat! Its bastard expensive to run mind...
Im not against upgrading it, but i need to justify the cost against the working unit tbh...
Water softners a thing to look at....? Whats the best thing without spending a million bucks....😫
Never had a problem with Monarch water softeners and reasonably priced , I'd maybe think hard and get both boiler and cylinder done fit weather compensation is a must now to save energy. Kop
  • Ultimate_Water_Softeners_Brochure.pdf
Reply to Unvented cylinder size in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all, looking for some recommendations for a slimline indirect unvented cylinder to go with a new system boiler that we're having installed...
Hi all. As the title says, I have a problem with an unvented cylinder I had installed last year where the first time I turn a hot tap on after the...
2K
H
Sizing an indirect H/W cylinder. What size of H/W cylinder would I need for a property with 9 bathrooms?
Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler. I may have solar panels in the future...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
