Hi, I'm looking to purchase a 300L unvented indirect cylinder to work with a standard heat only boiler.
I may have solar panels in the future, but likely the PV kind rather than the thermal kind, and won't be having heat pump in the future. So the cylinder would be connected to the boiler at least for the short term.
Assuming I only stick to a heat only boiler, I've heard these options would warm the water up quicker:
I'm looking at Joules, Kingspan and Telford brands for their twin/heat pump variations but open to suggestions for any others. It'll be installed in the garage and propety is 4 bedroom, 2 bathrooms and high usage individuals with long showers
Thank you.
- Twin Coil Solar version - Connect in series so x2 coils of around 0.6-0.9m^2 surface area to heat water up quicker
- Single Coil Heat Pump version - Coil has larger surface area ranging from 2.3-3m^2 which in turn heats water up quicker
- Combo of option 1 and 2
Thank you.
