Discuss unfinished tado extension installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
can someone please help? i have to go away tomorrow for work and the Mrs is NOT happy its not working....
The tado extension is still showing as an unfinished installation but not telling me why. I have done various different wire combinations for the combi boiler we have including replicating what was there previously;
L & N connected
Combos;
wire to 1
wire to 4
(Both tried in jump 1 and 2)
Wire to 1, bridge wire from L to 4
wire to 4, bridge wire from L to 1
There was a bridge wire in the old thermostat, hence trying it in this one
Each time with no luck, on the web app still showing as unfinished but connected. i can click on the installation instructions and tells me congratulations, its complete but it still shows as unfinished.
The bridge and smart thermostat are shown as completed installation.
Firmware on both smart thermostat and extension are the same
anyone help?
Thanks for reply
its an old baxi boiler. we had a honeywell wireless thermostat installed quite sometime ago and that has stopped working so a perfect excuse to upgrade.
When i took the old off, there are 3 cables with a bridge so i thought it would be nice easy like for like installation
Try that. Press and hold the button on the top of the extension kit until the led flashes rapidly. Once it’s connected to the other bits room stat the led will fade in and out.
From looking at the picture it appears that the third cable was in position b.
i have held the button down for 8 seconds to restart, then 3-5s so the led blinks rapidly. soon after it blinks 4 times and then a pause to show connected. i go to my tado login where it shows its connected but still unfinished installation.
sounds like its a connection issue
the opposite, its turned off but thats great because it was constantly heating and the house was upto 26 degrees so now its detected the thermostat, its cut off... so far id say so good. is definitely correct being in port 4, id have thought port 1 was correct
Reply to unfinished tado extension installation in the Plumbing Jobs | The Job-board area at PlumbersForums.net
