Discuss Underfloor heating flow won’t get up to temp in the USA area at PlumbersForums.net
Hi all. As above having issues with my UFH. Boiler fires up and works as normal . Issue is the return stays cold and as such when the boiler switches off when it reaches temp the flow stays about 35 degrees and the cycle continues . Have had it running with just one short loop open , pump on 3 . Doesn’t get hot . Had to turn on the radiators to get a good volume of hot water in the system and then turned on then 1 underfloor loop . Before the blending valve was real hot from the boiler but at the Manifold about 40 and return temp 35, flow meter is showing 4 ltr : min but turning the mixing valve up to max used to get return almost as hot as flow but nothing now , any ideas ? Thanks
Reply to Underfloor heating flow won’t get up to temp in the USA area at PlumbersForums.net
PSxxxxxx
