Discuss Turning a Reina Neva White Vertical Double Designer Radiator in the USA area at PlumbersForums.net
Morning!
Can a Reina Neva Vertical Double Designer Radiator 1800x472mm which is labelled front and back be turned around and still function optimally?
I have one which is dented on the front so would like to turn it front to the wall. I have been given conflicting advice whether this is possible and have got no response from multiple attempts to contact the manufacturer.
Thank you.
The only problem will be the brackets, they're designed to support under the headers (top and bottom) which are at the rear, so the supplied brackets will probably be too short.
on a double eg rails front and back your fine to turn it around providing the flow goes into the flow of the rad
Reply to Turning a Reina Neva White Vertical Double Designer Radiator in the USA area at PlumbersForums.net
