Discuss Tub diverter assistance in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi, all.
Was replacing the hot/cold cartridges and ran into a slight issue with replacing the diverter stem. I couldn't find any DIY info online about this type of a diverter (what style is this, btw?). The old rubber boot was welded inside, and I spent a good minute extracting it out (rubber first, then the bronze washer that sits at the end of the rubber boot). The new boot, from what it looks like, went on a bit crooked and the diverter works about 95% now with slight water leakage out of the faucet when in use. I don't like the way it feels when you operate it and wanted to see if there is a trick to putting these things in?
Should the rubber be greased up with rubber safe grease to make it easier to slide into the hole? How do you slide it in so it's straight? I was thinking about using a deep socket that fits inside the boot. It's a very tight fit (giggity), and i don't see how you can correct anything once the boot is in the hole. If it's crooked, there is no way that thing will come out in one piece.
Any advice is appreciated.
Reply to Tub diverter assistance in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
1K
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for...
