Discuss Trying to find out what make these tap heads are in the USA area at PlumbersForums.net
Can anyone help tell me what make these tap heads are please - look like Ideal Standard or Armitage but not found exact model
There are no Logo to be found on the taps. Not after cartridges on there own at this point. Have just replaced the washers on the valves ready for replacing once repair figured out.
Decided to drill out inside of head then got spline internal fitting for a differnt tap and with epoxy putty fitted it in the head. The repair has worked well and been working for 2 months now. When and If it failsI will replace the taps completely.
Why are you doing this?
What is the purpose- it’s quite annoying for “new posts” to fill up with old stuff that’s run it’s course.
Reply to Trying to find out what make these tap heads are in the USA area at PlumbersForums.net
