Discuss TRV's & Boiler+ (Boiler Plus) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Jerry
Evening All!
I am having a thick moment. Again.
What does boiler+ say about installing TRVs when swapping a boiler?
I have heard some say that you (always) need to fit TRVs when swapping a boiler. Others say that you dont now don't need TRVs with the uprated Boiler+ controls.
Any thoughts?
J
If your only changing the boiler then trvs are only a recomendation. If changing the boiler and radiators then they are required.
still only recommended even when your doing a new system
Evening All!
Any thoughts?
J
My understanding is boiler plus relates to the boiler only, whereas TRVs fall under domestic building compliance guide.
Only reccomended on boiler replacement only. New system but keeping existing pipework requires trvs.
Still only recommended table heading
Recommend minimum standards
Reply to TRV's & Boiler+ (Boiler Plus) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
