- Messages
- 359
Hi there
I am faced with an 4 yr old shower installation which has started to leak.
It's a wet room style shower floor with a trough drain. Only access is via a hole i cut in the ceiling below and even then it's limited. It's not the trap or waste pipe...
The cust has sili sealed all around the edge of the trough. Now i am faced with removing old silicon and redoing seal. There are 8 curved forms which accept the screws and as you can imagine it's not going to be easy to get in.
I would like to take the trough apart and check the seal between the top and the bottom halves but it doesn't seem possible.
Any advice? Do i spend hours picking out all the bits of old silicon? Can i use silicon remover on the plastic part of the trough? I have suggested taking the whole thing out but cust doesn't want to go down that route- he can't get those tiles again.
How about truck loads of CT1? Wish i had walked away now. Leak may not even only be around the drain for all i know it could be cracked grout, not that i can see any cracks ... arghgh !!
Please advise THANKS
