Discuss Traditional basin mixer tap, tap handles broken - help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
DavieB
Hi I have a traditional basin mixer tap both handles are now loose and spin freely without turning the water on or off.
How do I fix this issue? Can I replace the handles or do I need to replace the entire tap? Also, is this an easy DIY job or should I get a plumber?
Thanks a lot,
Davie
You can buy refresh kits, here's an example: Reviver Kits & Tap Spares, Tap Revivers | Taps | NoLinkingToThis
This will probably fix your problem even if you need to grind the seats.
Thanks a lot, I will look into this. Will it come with instructions on how to revive the tap?
Reply to Traditional basin mixer tap, tap handles broken - help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
