Discuss Towel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Anyone know the towels that soak up
Twice as much as others?
Thx
fo what, and to re use ?
Personally I don't understand the use of beach towels and a plumber, all those soaking wet towel slung in the van, just buy a ÂŁ35 wetvac from screwfix.
google Disney Magic Towel
just double up a normal towel, then leave it all wet and drippy in your van, as its too much bother hunting for george in my van:)
or you can go into any Williams branch and nick the towels from the staff bogs :):):)
Reply to Towel in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an electric towel rail which has stopped working. All the lights are flashing from blue to red and the boost light is flashing green I...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hi there, Can I simply undo the screws on this heater towel rail, make sure it's off and prop it up while I paint the wall behind it? I saw...
Hi all. The current towel rail is 1000mm x 600mm and ideally I'd like the pipes coming straight from the ground into the rail. The distance...
