Discuss Tooling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gasmanrob
I need to get a few bits breaker bar ring spanners and decent ratchet.
been looking at britool but noticed they are owned by the Stanley group who also own Mac and facom. All have lifetime warranty it's just how you go about replacing a broken tool that changes. My question is this are there any reasons to favour the other two over the britool set? Anyone use either of them? I wouldn't use them daily but certainly weekly I want something that's going to last but I'm not buying snap on. I have children that need feeding!
Many tools made today are just not the same as they used to be check out ebay for some not so new but still quality ...regards Turnpin:smile5:
Try looking at Teng tools. Very good stuff & not extremely costly.
Funny how these 'lifetime warranty's' are calculated.
Wear and tear is not covered, so unless the tool breaks in half you won't get it replaced.
Years ago I bough a sledge hammer with a 5 year warranty - with a fibreglass handle.
The handle broke on second swing - took it back and wanted it replaced.
Guess what - the handle is not covered under the warranty, only the head.
Guess what the Rep was told when I informed me of this?
well after having ÂŁ447 of a bill for servicing it last time aroud 6 months ago I wanted to do it my self this time , just changed the front brakes ÂŁ30 it cost me in materials! happy days! lad from work just paid a mechanic ÂŁ120 for changing the pads on his connect! oil change etc next
I've just treated myself to a new Bahco socket set off Amazon (Caulfied Industrial) in the sales, reduced from ÂŁ450 to ÂŁ190 ish... Decent range of sockets in 1/4, 3/8 & 1/2 in both AF & Metric... quality seems good too.
Did a scrap run today and when passing halfords stopped in and tried to replace ratchet again.... Yes sir not a problem.
RESULT!!
im also going to invest in some facom stuff. But no urgency now as ratchet is brand fine new!
always used draper tools as britool and snap on prices are stupid. If anything ever fails, just call draper in southampton and the bits arrive in the post. They also provide metabo drills etc, my first at 18 is still working, new carbons, they are in the post sir, no charge!! cant beat that, so never bothered looking elsewhere.
I used Bahco Socket sets and I also have Bahco ratchet spanners as you only need four spanners and you're covered for 16 sizes! excellent tool! For my podgers and ring spanners Etc I use King Dick. Well made tool
Reply to Tooling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
Hi, I am in NSW, AU, trying to replace the washers in some shower taps but have not been able to find a tool to undo the nuts holding the handles on. I can perhaps brute force it but this is a rented property so don't really want to do that! The nuts are octagonal! They have a slot in them but...
2K
I'm looking for a hole cutter or hole punch that you would use to cut a hole in a stainless steel sink for the waste to install into. Standard hole punches between 40 and 100mm for use with a hydraulic hand tool are available but I need a punch that makes the recess as well or a separate...
3K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
Hi, As some of you are aware, I am currently stuck in Italy running a shop that has nothing to do with plumbing :( Yesterday I thought I'd got most of what I needed to get done by lunchtime and was able to take the rest of the day 'off' (which actually means try to get done the things that are...
3K
