Discuss Toilet Waste pipe leak! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
I removed the tile floor in my bathroom to fit vinyl and I noticed that the loo now leaks slightly when I flush it. I haven’t put the vinyl down yet, so I can build up the floor under the loo if needed to put it back to the level it was, but maybe I can re-seat the big plastic flange slightly or something? What are my options?
Thanks and seasons cheer
Simon.
Where’s it leaking from and was the vinyl under the toilet ?
It was a tile floor that I lifted, so there's a 10mm gap now under the toilet. I haven't fitted the vinyl yet, but I'll probably run it under the toilet and fill the gap with something. It's leaking where the pan connector meets the porcelain. I assume it's leaking because shifting the tiles out dropped it down 10mm and disturbed the seal of the pan connector.
Toilet should have been removed I suspect you will need to re install it and a new pan connector flush pipe seals etc
Reply to Toilet Waste pipe leak! in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
