Discuss Toilet smell head scratcher!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan the plumber
Afternoon all,
I'm currently on a job where a "plumber" (basically DIY jobsworth friend of friend of the family!) has taken almost £15k from the customer for 2 of the worst bathroom refurbs I have seen!
I explained to the customer the only way to make them look better is to rip them out and start again but she is about to put the house on the market hence just literally wants them functional.
In the en-suite bathroom the jobsworth has installed a concealed cistern vanity unit toilet & basin. The problem is from this particular toilet, foul smells are coming back into the bathroom.
The house in question is a 5 bed detached & the stack is roughly 6 mtrs away from the en-suite. All is ok with the stack externally & is vented as it should be.
The smell is almost as though the water is stagnant, even when flushed numerous times! I have checked water seals in basin & shower after the toilet has been flushed but all is ok there and smell is deffo coming from the toilet!
The en-suite has been functional for years before he did the refit and the customer has never had a problem with smells before this!
Im thinking along the lines of to install an internal air admittance valve into the toilet waste pipe but thought I'd get a few opinions before I do this as not 100% convinced this will rectify the problem!?
Any opinions/thoughts/ideas!?
It sounds like the pan connectors isn't sealed into the soil stack, the only option is to remove and investigate really
Hi mate, remove toilet pan earlier this afternoon as wasn't even fixed to the floor! Pan Connector is a flexi but all looks to be ok here!
It's a strange one to be honest as it's almost as though the smell is being caused by the water in the pan as pretty much is a constant smell!
I know you said it's vented correctly, but there's not a faulty Aav stuck behind the vanity unit if it's a longish run?
No aav and never has been one...it's only since they changed the toilet that this smell appeared! He fitted the exact same toilet in the main bathroom & that appeares to be ok regarding smells (still didn't fix to floor though!).
The en-suite is very rarely used to be honest but still the smell is there! The smell gets more prominent when the toilet is flushed & it appears to be coming from within the pan as opposed to behind/pan connector!
I`ve swopped toilets over in the past to prove my point to the customer.
What you reckon to installing an AAV? I'm a little reluctant to put one in unless I really have to due the where he has positioned the vanity units.....it could be opening a huge can of worms!
Spent the rest of the afternoon removing grout where sealant should be! The idiot had only grouted between the tray & tile....not a bit of sealant in sight! The customer said it leaks when she uses the shower......hmmmmm you don't say :32:
Reply to Toilet smell head scratcher!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a mystery, my bathroom has a sewage smell appears to get far worse 5pm-9pm. I have plugged my bathroom/sink with plugs and its 100%...
Hi, So i have lived in my house for 20+ years, (1990 build) its a detached property, corner plot with various manholes in the garden. In the...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Neighbour can smell sewage from our toilet. A very smelly problem – our neighbour can smell sewage from our toilet. We live in a semi-detached...
3K
Hi all, I've been getting some plumbing quotes for an en suite project for my home (based in the east of England), and wanted to find out...
