Discuss Toilet seat needs tightening in the USA area at PlumbersForums.net
I have a Egesermix toilet and the seat has come loose, as it’s an all in one system I don’t have access to tighten the bolts. Any advice on how to fix it would be greatly appreciated. I’ve attached a photo if that helps identify the problem.
Please check your spelling of the toilet or supply a link as the photo isn`t showing this end. Hoping you don`t have to remove the whole thing just for this. ;)
Reply to Toilet seat needs tightening in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The...
