Discuss Toilet seat needs tightening in the USA area at PlumbersForums.net
I have a Egesermix toilet and the seat has come loose, as it’s an all in one system I don’t have access to tighten the bolts. Any advice on how to fix it would be greatly appreciated. I’ve attached a photo if that helps identify the problem.
Please check your spelling of the toilet or supply a link as the photo isn`t showing this end. Hoping you don`t have to remove the whole thing just for this. ;)
Reply to Toilet seat needs tightening in the USA area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
