Discuss TMV 2 and Worcester Junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
kozak1968
Are there any issues with installing a TMV2 on the supplies to a kitchen sink?The boiler is a Worcester junior 28 which has no temperature control on the hot water. The customer is old and wants to reduce the temperature of the hot water.
the only issue i can see is a bit longer heat up times other than that dont think there is a issue but if your that concerned phone Worcester up to double check can give you the new phone no if you want?
Just thought I should check to see if there are problems with combis and TMVs.
seen plenty of andrews with the same set up (mains pressure hot water)
Reply to TMV 2 and Worcester Junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have had an ongoing issue with low hot water temperatures in a school. During the recent repair of a leak, the plumbers isolated the hot...
All of my London house plumbing is being redone, with a heatpump heating a DHW tank, and a hot water recirculation system. With the hot water...
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted...
