Discuss Tinning flux worth it or not. in the DIY Plumbing Forum area at PlumbersForums.net
Seen a few videos where they used tinning flux. Seems to do the job better, to my eyes. Is it worth the extra expense?
Not wras approved for drinking water as you will find it’s leaded
The Oatey 95 one isn't leaded. Not sure if it's WRAS approved.
Putting aside WRAS as I'm currently abroad where WRAS doesn't apply anyway, Oatey claims it's okay for drinking water and the ingredients in it would seem to either flush out on commissioning or be suitable for the potable pipework. Though I have to agree with Last Plumber that for general use I don't see the need.
If you don't like Laco and want something that is slightly more tolerant of a bit of residual water in the pipework, Fluxite (thick and greasy) is 'the most effective flux known' and seems to be non-corrosive. I personally prefer it to Laco. Templar's Telux may be similar to Fluxite but I've yet to experiment with it.
Duly noted. Why do you prefer to Laco can I ask?
When working on existing heating systems, when I'm fluxed and soldering, the smallest drip of water and it's the joint ruined. Also, I once tried leaving 3 types of flux on a copper pipe for several days. Everflux and Laco turned the pipe green. Fluxite just sat there. That said, I suspect Laco probably washes out more easily once you're done soldering and are flushing, whereas Fluxite probably needs hot water.
Reply to Tinning flux worth it or not. in the DIY Plumbing Forum area at PlumbersForums.net
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks...
I am considering replacing my existing boiler with the new 2023 Vaillant ecotec plus 625 boiler. I currently have 3 x Heatmiser neoStat...
I'm a council tenant and my bathroom basin is broken and needs replacing, it has standard pillar taps. Do you know if councils would ever replace...
